Engine is out need help!!!!!
ORIGINAL: addiction2bass
it might be a bad valve... maybe bent and sticking open or cracked or busted piece or something if its leaking out the valve at all times.... just a posibility..... if you can do a leak down test... hook up a hose to the cylinder and with a gauge and valve and air fill, fill the cylinder with some where around 100PSI or more and then close the valve... and then see if the gauge PSI goes down.... if it does somethings leaking and its either a bad valve or sticking valve, or just damaged valve. if it is.... might as well pull the head and check the valves and replaced the head gasket as well....
Ty for your help
maybe if you bought the same shade color it would look decent. but IMO it just looks rice.
i would have just kept it clean or painted it black. but again thats just IMO.
Mikester
Jun 17, 2014 05:47 AM
1995CivicEXBMF
Aug 19, 2010 08:01 PM
hondaslamer2
Jun 27, 2010 11:05 AM
xxeddixx
Aug 24, 2006 05:06 PM
Legend1011
Apr 22, 2006 02:30 AM
