Engine stutters at idle with AC on....
Old Aug 1, 2008 | 05:01 PM
98honda4dr's Avatar
Post Engine stutters at idle with AC on....
About every 10 seconds. Its a 98 civic lx. But idles fine with the ac off and runs fine with the ac on or off. Any ideas on how to fix this?
Old Aug 1, 2008 | 05:13 PM
Is the CEL ON?
Three items to consider:
1) Idle speed adjustment too low - check idle adjustment screw on the throttle body
2) Malfunctioning IACV on throttle body - try cleaning (see forum DIY)
3) A problem with the A/C signal to the ECU - the A/C system sends a signal to the ECU to increase idle speed. There could be a problem with this circuit.
Old Aug 1, 2008 | 05:42 PM
Sigracer10's Avatar
check the stuff stated above ^^^,
but also something to consider is that the compressor turns itself on and off while its turned on at the a/c controls. so the engine might just be shuddering when the compressor turns back on and the engine takes a second to catch up with the extra load that the compressor puts on it.
you can notice this on most four cylinder cars, but it is only a minor fluxuation, nothing crazy. but if your car is doing it very bad, then there may be a problem somwhere in the a/c system.
Old Aug 2, 2008 | 02:23 PM
mundy5's Avatar
also, have you recently put in more refrigerant? You might have put in too much
incogneato
Jul 30, 2007 12:17 PM
Ashtrey634
May 11, 2007 03:26 AM
Ashtrey634
Apr 19, 2007 02:02 PM
Drunkgoose
Apr 19, 2007 12:37 AM
b1pig
Mar 22, 2006 12:37 PM
