engine ticks too loud
Old Jul 23, 2008 | 09:40 PM
foozball's Avatar
Default engine ticks too loud
Hi guys, I just bought a 95 civic 4 dr. the guy had the engine serviced about 6 months ago, new timing belt, water pump ect. should the engine be makeing that ticking lifter noise also it
has the original clutch, at 150 K how much longer should I expect the clutch to last? any help
appreciated.
Old Jul 23, 2008 | 10:11 PM
Default RE: engine ticks too loud
Is the clicking noise heard at idle, normal running, or accelerating?
If the clutch wasn't abused, you might get 20-30k miles. Is the clutch slipping or chattering?
Old Jul 23, 2008 | 10:36 PM
isn't the ticking normal on a honda engine?
Old Jul 24, 2008 | 06:58 AM
bakertime's Avatar
Ticking often is due to a needed valve lash adjustment. Some Honda have a loud injector pulse, others have LMA's (VTEC motors only) that are bad and tick. Could be any of the three if you hear it at idle.
Have the valves adjusted first, and you can hold a screwdriver up to the injectors and your ear to tell if the ticking is coming from them.
islandtuner
May 4, 2009 08:54 AM
Apostle
Aug 23, 2008 11:14 AM
HomeboyFernando
Jul 27, 2008 10:12 PM
clickagent75
Jun 20, 2007 06:35 PM
TrAvMaNFTW
Feb 19, 2006 12:19 PM
