filter
Old Apr 27, 2010 | 01:32 PM
George4242's Avatar
Default filter
hello i bought a cold air intake and i got a little filter i have no clue where it goes, can someone tell me or show me where it goes? thanks
Old Apr 28, 2010 | 08:05 AM
The little filter goes on the port on the valve cover that had a pipe or hose leading to the stock intake. While the engine runs, the PCV system draws air in through the valve cover port to clear vapors out of the crankcase. If it isn't filtered air, dust will get into the engine.
Old Apr 29, 2010 | 11:15 AM
George4242's Avatar
what do i do with the hose coming out of the valve cover? plug it?
Old Apr 29, 2010 | 11:28 AM
no dont plug it, you can put a small filter on the valve cover hole or run a hose from it to the new intake
Old Apr 29, 2010 | 11:39 AM
George4242's Avatar
if i put the filter on the valve cover hole. what do i do with the hose that goes from the intake to the valve cover? cause i have the hose going from the intake to the valve cover. do i just leave the hole to the intake off?
Old Apr 29, 2010 | 11:48 AM
If your new intake has a hose branched off of it like the stock intake, connect the hose to the valve cover and don't use the little filter.
Old Apr 29, 2010 | 02:02 PM
1992 civic driver's Avatar
if you have the filter hook it up on the valve cover its better just plug the hole on your intake if you have one.
kenji51590
Feb 24, 2011 05:24 PM
JDMracer00
Aug 27, 2005 12:43 PM
green98lxsedan
Jun 27, 2004 02:18 PM
princey
May 30, 2004 01:46 PM
iNTRuDeR
May 2, 2004 11:02 AM
