fog lights help
Old Apr 12, 2007 | 07:36 AM
nissandude83's Avatar
Default fog lights help
Okay so my buddy has a 2006 SI and he got some fog lights off of ebay and can't get them to work. They are supposed to be stock lights and they look like they are. The lights came with the relay and all wiring even the signal wire with brown terminal to plug into the stock wire. Our problem is that we put it all together except mounting the lights to the car and now light. The plugs were all in and a fuse was in the needed spot on the fuse panel, we tried with the headlights on and off and hi-beams on and off but no luck. Does anyone have any insight for us? Thanks.
Old Apr 12, 2007 | 07:43 AM
danomatic93's Avatar
June 2010 ROTM
Default RE: fog lights help
Are the fog lights grounded? No ground = no light. Otherwise check that the bulbs work, that is, if all your wiring is correct.
Old Apr 12, 2007 | 09:05 AM
wires were grounded straight to the battery and the bulbs look okay.
Old Apr 12, 2007 | 12:45 PM
Fiirkan's Avatar
you can't ground to the battery
Old Apr 12, 2007 | 03:38 PM
cderalow's Avatar
ORIGINAL: nissandude83
you have to ground to body or other source of ground
itzcorky
Sep 21, 2011 07:45 AM
DjHagios
Aug 13, 2010 10:21 PM
JenniferLa
Dec 6, 2007 02:24 PM
CiViC_NaTioN
Mar 3, 2007 04:34 PM
fvstrbballplyr
South
Jul 15, 2006 03:12 AM
