low brake fluid
Old Apr 12, 2007 | 04:47 PM
Live_4it's Avatar
Default low brake fluid
I noticed that the brake fluid level is a little lower than the line inside the brake fluid resevoir. I bought some brake fluid at a honda dealership and my question is; do I justpour it in the resevoirtill it's at the line, or do I need to bleed the brakes or is there some kind of process to it?
Old Apr 12, 2007 | 04:50 PM
ej6buddy's Avatar
Default RE: low brake fluid
just pour it to the line, the cap is pressurized, and you only need to bleed the brakes is when you replace brake lines, calipers, etc.
Old Apr 12, 2007 | 04:53 PM
Live_4it's Avatar
Ok I just wanted to be sure....
should I check to see if there is a leak anywhere. I don't think there is but how could the brake fluid level go down if there isn't?
Old Apr 12, 2007 | 04:54 PM
ej6buddy's Avatar
burns up is my guess, not 100% sure, it just needs to be checked every now and then.
DaHonDa
Mar 22, 2015 08:47 AM
pippo
Jun 16, 2014 12:08 PM
Ed Fisher
Aug 20, 2009 11:47 AM
enigma34
May 13, 2009 06:41 PM
galaxygreycivic07
Nov 14, 2006 09:35 PM
