front Quater pannel removal
Old Aug 1, 2007 | 04:14 PM
Chaos's Avatar
Default front Quater pannel removal
Anyone got any good advice on removing the front quater pannels? or fenders or flares or whatever you guys call them. As u know, I skittled a roo at a hundred something clicks, and now u gotta replace some mashed up pannels. Im attempting to remove the quaters today I think. Is it front bar first? do i need to take the door off? Any guidance would be greatly appreciated. Cheers
Old Aug 1, 2007 | 04:35 PM
ej6buddy's Avatar
Default RE: front Quater pannel removal
ok, pop your hood, open your door, get your 12mm socket with extensions. remove the little clips in the fender that is attached to the plastic. then remove the 2-3 bolts on the fender in the engine compartment. then remove the side skirts and you'll see an additional 2 more bolts. and then hyper extend the door a little, and it will reveal 1-2 bolts that you need to remove. i'm having a brain fart on whether how many bolts total there are. i'd suggest removing the fender plastic and door jam bolts first.
Old Aug 8, 2007 | 05:04 PM
Chaos's Avatar
Ok, bumper is off, lights are out, and every thing is sweet EXCEPT there is 2 bolts under the black skirting under the doors, which i cant get to without removing the skirting. Anyone know how to remove this? The Aus Civics are remarkably different to the US Civics but the concept is the same. Thanks for your help.
Old Aug 8, 2007 | 05:23 PM
ej6buddy's Avatar
ORIGINAL: Chaos
i told you you'd have to remove the side skirts. all you do is look under the side skirts, and you'll see about 4 plastic tabs with screws. all you do is unscrew them and pop them out. then look in front fender liners and you'll find one or two more screws that attach to the side skirt. remove them and go to the rear fender, and you just firmly tap on the rear of the side skirt, and it should slide to the front of the car and pop right off (considering you removed all the screws). then it will reveal the two remaining bolts on the fender.
Old Aug 8, 2007 | 06:40 PM
Chaos's Avatar
Excellent, thanks mate, done and done. Only problem now is I pulled the quarters off, but the new ones that were suposed to arrive today havnt. Damn military mail, ITS NOT A BOMB, YOU DONT NEED TO X-RAY IT!
Old Aug 8, 2007 | 06:45 PM
ej6buddy's Avatar
nice, good luck, just make sure all of the little white tabs are aligned properly when you reinstall the side skirt.
texasmade
Apr 28, 2010 08:59 PM
omgxitsxaxhatch
Nov 28, 2006 10:53 PM
civicexracer
Aug 28, 2005 12:01 PM
kennyl_10
Jul 26, 2005 10:07 PM
outlawzz23
Aug 3, 2004 04:59 AM
