Problem starting my car. (97 Civic EX)
I've had this problem occasionally where my car wouldn't start, but after a while it would. But today was different, my car wouldn't start at all. Again, i have a 1997 Honda Civic EX, AT. The accessory slots work just fine, like my radio, ac, and everything, but when i go to start my car, it doesnt even turn over, crank, or anything. I think i said everything that is relevent but if you need more info, i can tell you. Can anyone help me?
Probably the starter itself. When worn out, they get where they sometimes go, sometimes not, of course with every start the chances of "not" get higher. Another thing that can do it is the safety switch, if you can shift in and out of park a few times and get it to reliably start it would be that. Also make sure the cable connections to the battery are tight.
The starter can be tested by disconnecting the small wire at the starter, connect a jumper wire between the terminal on the starter for the small wire and the battery (+). Now the engine should turn. But before you do this you want to be sure the car won't move, which means: key OFF, Transmission in Park, and e-brake set. If it does crank in the jumper test but you can't start it with the key that means the battery and starter are OK but the safety switch, key switch, anti-theft, relay etc. are the problem.
djt
Jun 21, 2008 07:48 AM
Bryan1987
Mar 12, 2008 08:54 AM
n8te81
Mar 9, 2008 04:45 PM
totenkopf
May 31, 2007 03:36 PM
