Funny power loss!!
Old May 23, 2010 | 09:19 AM
chrisgerman1983's Avatar
Default Funny power loss!!
So i know people like to say that Hondas are hamster powered but mine was almost mouse powered. I was noticing that it was really hesitating and felt really weak. so i figured id put some seafoam in it and change the air filter and stuff. When i pulled the filter out i quickly realized why it was so gutless.... The airbox was packed with fiberglass insulation and the filter was chewed almost through good thing the little ****er never made it through! i am sure the glass would not have done any good inside the motor! It has never been parked for longer then a day so it must have happened overnight.... Good reason to only use filters with mesh reinforcment!!!
Old May 23, 2010 | 11:49 AM
Might help to mention what year/trim/mods.
Always start by checking the plugs, wire, cap, and rotor (assuming your Civic is a 2000 or older).
Any CEL codes?
Old May 23, 2010 | 06:04 PM
guess you never read the whole post i already solved the issue... there was a rat nest in the airbox lol, no it never set off any codes. I thought it would have, with it being that restricted
Old May 23, 2010 | 08:27 PM
So if you already solved the problem why did you make a thread? You're welcome here on the site I just don't understand why someone would register an account just to create a thread about a problem that they don't need help with.
Also, you never clearly said in your first post that the problem was a rat. I understand your pun now that you've made your second post, but it didn't really make sense without knowing what the problem was.
Old May 23, 2010 | 08:50 PM
obviously niether of you know how to read. I pretty clearly stated that there was material in the airbox from a mouse. that was clogging the airbox. it was pretty clear. i thought it was funny so i thought i would share.... i never asked what could cause a mouse to get in the airbox... learn to read!!
Old May 23, 2010 | 08:52 PM
I never said you asked what could cause a mouse to get in the airbox... learn to read!
Ben
Jan 19, 2007 04:53 PM
carlover
Aug 2, 2005 10:07 PM
rzimmer11
Mar 15, 2005 11:32 PM
islandguy
Oct 23, 2004 01:20 PM
jjgarcia
Aug 2, 2004 10:26 AM
