Gas pedal not working well
my gas pedal doesn't go back up as fast as it used to be when i release my foot. i just replaced the flywheel and clutch. is there anythign i need to check? maybe spring or something that usually push the pedal back? thanks.
The springs on the throttle body pull the throttle closed and the pedal back up. There are two springs so it will still work somewhat in case one breaks, make sure that both are good. When you pull the throttle open at the throttle body and let it go, it should snap right back. Maybe there is some gunk in the pivots, though usually a dirty throttle body will stick closed.
If the cable is sticky, a new one is not very expensive. There's no way to take the cable apart and relubricate it.
gunaa
Oct 22, 2009 11:36 AM
kaila
May 6, 2007 11:08 PM
chrisroug
Oct 2, 2006 11:36 AM
THE_CRIPPLER
Oct 5, 2005 04:08 AM
