Gas Smell in Air Vents. How to change fuel filter?
Old Mar 26, 2010 | 06:48 AM
celinaroc's Avatar
Default Gas Smell in Air Vents. How to change fuel filter?
The car smells like gas and when i turn on my A/C i can smell it coming though the vents.
It sounds like a leak to me, however i seem to be getting about 29mpg.
Should I change the fuel filter?
i saw a how to when i was looking through other posts but now i cannot find it.
Old Mar 26, 2010 | 07:59 AM
Don't drive a car with a fuel leak, even a small leak makes it very likely to catch on fire. Look under the hood and find the leak, and repair accordingly.
Old Mar 26, 2010 | 08:29 AM
supersize's Avatar
Sir Banned-a-lot
the fuel filter is right on the firewall near the battery, you just unbolt, remove the line, replace and ur done, its not hard at all, but i dont think thats your problome
Old Mar 26, 2010 | 10:09 AM
MaximusFunk's Avatar
I smelled gas through air vents when I bashed my fuel rail with my knuckle while adjusting valve lash. I checked and there was no gas spraying in my engine bay, but one of the injectors was turned slightly, so I adjusted it and havnt had the smell since. prolly wont help you, but just putting it out there.
Old Mar 26, 2010 | 09:27 PM
celinaroc's Avatar
Thanks...
If its leaking into the A/c where could it be leaking from?
Old Mar 26, 2010 | 09:48 PM
The vapor is just coming into the vents when the recirc is off. Check the fuel line connections around the fuel filter and injectors and the vacuum/vent hoses on the evap canister.
Old Mar 27, 2010 | 08:59 AM
Vapors from anywhere under the hood will get sucked into the A/C. The A/C takes in air through the little grille below the windshield.
Old Mar 27, 2010 | 12:03 PM
celinaroc's Avatar
problem solved! thank you
Old Mar 27, 2010 | 12:27 PM
Dipsetcivic117's Avatar
how did you solve your problem. that way other people can find a answer when having the same issue
kenji51590
Feb 24, 2011 05:24 PM
edwinss4
Dec 6, 2010 06:10 PM
Johnny Appleseed
Jul 23, 2010 10:48 PM
new_2_civics
Apr 3, 2010 04:01 PM
Meatwad83
Jul 20, 2005 10:47 PM
