general d15z6 swap q
Old Sep 1, 2007 | 05:36 AM
redridinhood's Avatar
Default general d15z6 swap q
If i put a z6 in my 93 lx will i have to swap ecu's or is it plug and play (except the vtec will have to be wired up)? Anyone have a link on how to wire up the vtec then to? Sorry to be such a noob lol Thanks in advance
Old Sep 1, 2007 | 08:22 AM
BrokenRex's Avatar
Default RE: general d15z6 swap q
ECUs will need to be swapped. your ECU doesn't have any vtec control, so adding the four necessary wires will do no good, as the pin on the ECU isn't there.
Old Sep 1, 2007 | 08:24 AM
danomatic93's Avatar
June 2010 ROTM
What engine do you have right now? That'll make a difference if it's plug and play or not. btw, it's a D16Z6, there's no such thing as a d15z6.
Either way, it would be best to get the ECU from an EX/Si Civic 92-95. If you're on a budget there ways, but I wouldn't cheap out on that.
Old Sep 1, 2007 | 09:55 AM
Marty's Avatar
there is too a d15z6
D15Z6
[ul][*]VTEC-E[*]Found in:
[ul][*]1996-2000 Honda Civic LS (European Market)
[ul][*]Displacement: 1493 cm3[*]Bore and Stroke: 75 mm X 84.5 mm[*]Rod Length: 137 mm[*]Compression: 9.6:1[*]Power: 114 hp @ 6500 rpm[*]Torque: 98 ft·lbf (141 Nm) @ 5400 rpm[*]VTEC Switchover: 2500 rpm (3500rpm in 5th gear)[*]Valvetrain: SOHC VTEC-E (4 valves per cylinder)[*]Fuel Control: PGM-FI MPFI [/ul][/ul][/ul]
Old Sep 1, 2007 | 11:44 AM
ya i meant d16z6 sorry lol type o lol
What is the the name of the ex/si ecu is it the p28 or p08 or what?
Everything else is direct bolt in correct?
Old Sep 1, 2007 | 12:30 PM
Marty's Avatar
p28
Old Sep 1, 2007 | 01:27 PM
sweet thanks marty
Old Sep 6, 2007 | 02:57 PM
MODA's Avatar
i wuz working on doin the same thing to my car!!.... did u do it? how did it go? let me knw..[sm=helpout.gif]. k
im figuring out everything ima need n dnt wana mess up...[sm=smiley24.gif]
Old Sep 6, 2007 | 08:08 PM
havent swaped yet sorry still figuring out if i have the funds for a b20 swap if not ill just throw in a d15 vtec or the z6........
Old Sep 7, 2007 | 09:22 AM
MODA's Avatar
oh okay... just let me knw
good luck wit da $$
duque0915
Jun 22, 2010 04:37 PM
R883
EK Swaps
Mar 29, 2009 04:14 PM
WILMER007
Dec 24, 2008 11:46 PM
mishaelpl
Mar 26, 2008 02:09 PM
civics101
EK Swaps
Feb 28, 2007 11:31 PM
