ghetto window
Old Feb 8, 2006 | 05:42 PM
smokingemcee's Avatar
Default ghetto window
Ok I have ignored this since I got my car but it's time to fix this now! My driver side window doesn't roll up all the way or straight up. Is there a way to adjust it? Or do I have to replace the whole track?
Old Feb 9, 2006 | 01:03 AM
civicfan87's Avatar
Default RE: ghetto window
i have the same problem on my driver side window. the only way to roll it up all the way is to push it. i found the problem though, the track where the motor is cranking the window has teeth like gooves on it and three of them are worn down. so the grooves aren't caught and the window gets stuck. the ionly way to fix it i think would to buy a whole new window motor but im not sure.
Old Feb 9, 2006 | 02:41 AM
99civic_boosted's Avatar
More then likely it is your window regulator and aren't to bad to replace.
Old Feb 9, 2006 | 11:12 AM
95CIVICUS's Avatar
my passenger side doesnt roll up very quickly. my drivers side window used to do it as well but i took the panel off and cleaned the track and oiled it and then I had wipe off the window from where i accidentally sprayed it with WD-40.
Old Feb 9, 2006 | 06:55 PM
I'm talking about a manual window
Old Feb 10, 2006 | 09:39 AM
my_hidden_romance's Avatar
ur track might be bent a bit.. my passenger side window was sluggish like this... i fixed it...[IMG][/IMG]
see.. its just per. down now!!
dblclutchin
Nov 12, 2006 11:29 PM
01silverbullet
Sep 20, 2006 06:48 AM
StifflersMom
May 30, 2006 08:25 AM
MccM
Apr 8, 2006 09:07 AM
Forty04
Dec 2, 2005 07:10 PM
