Glow Gauges--can't find 12v source
ORIGINAL: Chimera02EX
You could just splice into the ignition wire and run an inline fuse, that way if you want to add more you can just keep splicing into the fused line.
I don't suggest it, but I actually have all my electronics (gauge lights, auxiliary fogs, halos, LED's, etc.) coming directly off my battery. I found that if I put enough stuff on it, it wouldn't short anything out!!!
I just ran a long wire behind my dash and had stuff jumping off it going to whatever needs power. Wierd, but it adds my own flair to it.
Hi
I just fitted some blue interior neons in the footwells that need a 12v source. I can't seem to find any way of getting wires through from the area under the glove compartment or any other, so i can send wires through to the bonnet, and into the battery.....any ideas? I drive a Civic sport,coupe (yr 2000). Otherwise....the fuses are just behind the coin drop down thing by the steering. I tried hooking the neon lights red wire into a fuse end, but no success....where should I put the (-)?? Theres the (+) which will be the power in, but to complete the circuit, where can I put it? (how does putting it on a bolt create a circuit?).....Any help that can get this sorted would be appreicated!!!!!!!!!!!
Ideas for a positive source? I can't get to the abttery and I want to avoid splicing into exisiting live wires. THe fuse box is there, but wrapping wire around one of the fuse's metal parts doesn't seem to work???
ORIGINAL: yaserkali
Thanks fellas! In the end the place where i got my new sony unit fitted...they fused and wired it into the power-in of my unit(!) So its all sorted! Next plan....stage 3 turbo(!!!)...gotta find a mechanic around London though....hmmmm - otherwise going to have to get a decat exhaust system b4 that....
