ground wires
Old May 1, 2006 | 09:51 PM
dogma's Avatar
Default ground wires
Hi,
Do these things work?
Click Here
Old May 2, 2006 | 08:20 AM
riceburner700's Avatar
Default RE: ground wires
i put them on my car and it helped stable out the feel of the throttle and how it opened and closed. the car also was more stable the higher the rpms got... over all i would rate them a B+
Old May 2, 2006 | 12:48 PM
sillyredcivic's Avatar
I think the voltage stabilizer is a good idea but I wouldn't waste money on a grounding kit. You can make it yourself out of some 4 gauge available at your local audio shop and a few crimps rins, gold if you want show nickel plated if you want to save some coin. Just my thoughts. If you are deadset on cosmetic then go with the prefab ground kit, otherwise just make it yourself. And yes doing the gtround upgrade made my car idle smoother and throttle response was slightly nicer. worth doing either way.
Old May 2, 2006 | 01:55 PM
civicexracer's Avatar
^ditto.. u can make ur own ground kit pretty easily and cheap. ill be making one at some point in time, just have no idea when ill get around to it...
clutchjunkie
Aug 13, 2006 08:02 AM
FlipHKD720
May 25, 2006 06:11 AM
outlaw2049
Apr 28, 2006 10:10 AM
smokingemcee
May 1, 2005 01:34 PM
smokingemcee
May 1, 2005 02:08 AM
