GRR! Engine turns off while driving, radio/lights still work, garage baffled!
Old Jun 9, 2009 | 11:46 AM
Originally Posted by kellyjaye
I know, thats the problem im running into. When the shop gets my car, it works fine and has the last 2 times Ive taken it in and all the tests say that as well. I dont know whats causing it to break down so I cant tell them that either, its happened twice while driving and twice while parked. Its broke down again now and i really dont know what to do unless there is such thing as a mobile mechanic with computers and all that. Im just clueless as what to do. Right now all I can think is have it towed to a Honda dealer :-(
Again, don't rely on the mechanics. You can help pinpoint the problem. Learn to check for spark and listen for the low humming noise of the fuel pump. And then when the engine won't start, check for both. I'll bet that when you determine whether the problem is fuel or spark, we will also be able to help you fix the problem at home (save $$$).
Old Jun 9, 2009 | 11:49 AM
The lights seem to be working normal so the next step is to check for spark. You will need a spare spark plug and an assistant to turn the key.
Hopefully it will stay dead for a while so the problem can be found.
Old Jun 9, 2009 | 11:57 AM
kellyjaye's Avatar
Since plugs are cheap, what if I just went ahead and replaced all 4?
Old Jun 9, 2009 | 12:01 PM
It would be highly unlikely for bad plugs to cause a no start.
Stick to this plan -- Listen for the fuel pump and check for spark!!!!
Old Jun 9, 2009 | 02:34 PM
kellyjaye's Avatar
Angry
We were trying to jump it after work today though we knew nothing would probably happen. While doing that, we pulled the plug cables. One of them was just laying in there, it didnt pop on and off like on the other plugs. We looked at it and the inside of the cable looked real rusted and dry rotted or something. My cables were under warranty so we got them replaced, came back and tried them...still nothing!!! I did get 4 new spark plugs also but didnt have a tool to use at the time but will try that tomorrow when I get back to work. Dont know what to thing or try anymore. I really dont know what a fuel pump sounds like to know it when I hear it being everything sounds now as it always has. I read up on your spark test but I didnt understand that either, maybe it will make more sense to one of my coworkers. If all else fails, just gonna get it towed to Honda. If they cant find a problem or if its working when they get it, I guess I just need to scrap it and get a new vehicle :-(
Old Jun 9, 2009 | 02:45 PM
Fuel pump -- when the key is tuned to ON(II), you will hear a low humming noise in the rear (under the seats) for 2 seconds. If need be, have a friend turn the key while you put your ear to the fuel fill hole with the cap off.
Spark -- seriously, if you have any specific questions about how to check for spark, just ask me.
If you can determine whether you lack fuel or spark, you are half way home!
Old Jun 10, 2009 | 06:50 AM
kellyjaye's Avatar
Today, a friend who knows more of what she is doing listened for the fuel pump and heard it, pointed it out to me. But at the same time, my car started up this morning! I guess the thing to do is listen for the fuel pump when the car wont start. So when the engine dies on me again and I go to restart it and it doesnt, I should listen for a fuel pump then? I wasnt hearing anything yesterday but not sure if that was because i didnt know what to listen for or if it just wasnt working.
I have some new spark plugs that im going to change out this afternoon also. Will see what happens then!
Old Jun 10, 2009 | 06:58 AM
...So when the engine dies on me again and I go to restart it and it doesnt, I should listen for a fuel pump then?
Yes. And also check for spark at the plugs.
Old Jun 10, 2009 | 07:49 AM
kellyjaye's Avatar
Going to keep that in mind, I mentioned that to my friend also and someone else. They really made it sound like you can really hurt yourself if you dont do it right or mess something up real bad, even they were a little nervous about it. If they are, i dont think I can trust myself to do it either. Will see what happens...
Old Jun 11, 2009 | 03:38 PM
kellyjaye's Avatar
ok...internet research is telling me its the solder joints in the main relay are probably cracking. I found the relay but how in hell do you unscrew the bolt holding it up? I am already upside down in the drivers seat just to see it and barely can even touch it with my fingers. I really dont think they make rachets that small. How do i get to it and take it off?
