Hard start... Choppy accelerating. HELP!
Old Feb 19, 2011 | 07:07 PM
nocrimenhonda's Avatar
Default Hard start... Choppy accelerating. HELP!
Have a 1998 Civic Lx I have replaced .. Fuel pump, Fuel filter, plugs, distributor cap, Rotor.. Still has not fixed the problem. The wires look new and i figured it would throw a CEL. There is no CEL on right now. Any one have ANY suggestions on what I can test/ replace to get this car running right? Thanks!
For what it is worth when the car warms up, it runs great real smooth like nothing is wrong with it. But whens she's cold real choppy!? Thanks for you advise.
Old Feb 20, 2011 | 08:30 AM
Check the timing, both cam and spark. ECU test jumper must be installed to check spark timing.
Check for dead cylinders by disconnecting the fuel injectors one at a time. Do not do the old dead cylinder test of disconnecting the spark plug wires while the engine is running. That is prone to blow the coil.
You can't tell if spark wires are bad by looking. Usually though they won't cause hard starting. If the problem is primarily misfiring when heavy throttle is applied at low rpm, replace the wires.
Old Feb 21, 2011 | 04:47 PM
Ok so if the timing is off wouldnt the car run bad at all times? and the injector would be the same? just asking. i went to the junk yard today and replaced the map sensor .. which still didnt fix the problem. also is there a way to test the wires? thanks again.
David_S
Oct 24, 2013 10:06 AM
bk7794
May 7, 2012 02:28 PM
The Coz
Oct 5, 2006 03:46 PM
My04Civic
Aug 2, 2006 12:44 PM
vatpitt
May 8, 2005 02:12 PM
