HELP on Buying Integra
Old May 29, 2008 | 02:57 AM
PaTKRider's Avatar
Default HELP on Buying Integra
I am looking to buy this 1992 integra with a b18a1, and when i started it it sounded like there was a tapping sound or knock. When i pressed the gas , you couldnt hear the tap/knock anymore, and itdid drivepretty good. I just started playing with hondas and i dont know much bout them yet. I always used to be a domestic guy. Im really into this car, but i am a little concerned about the noise.
Thanks for the help.
Old May 29, 2008 | 06:17 AM
colby_666's Avatar
Default RE: HELP on Buying Integra
some of the rockers might need to be adjusted ( i think thats what they are called) the piece that the cams push up on, if you have the guide/how to book, it tells how to do it, but at certain points during the rotation of the motor there is supposed to be a certain amount of space between them, it's not that hard to adjust them if you have some simple tools like sockets, and the shim stock (i forget what the distance is), and some wrenches. the same thing happened to me when i bought a civic i dont have anymore, when the motor is slow you can hear it but not when it speeds up you cant.
im not saying this is the problem but it could be
Old May 29, 2008 | 07:21 AM
mundy5's Avatar
+1; it sounds like a valve clearance problem to me as well. The clearances are listed on a sticker under the hood. I have not done this adjustment but it does look pretty straightforward. The main concern is that it needs to be done on the car after it's been cooled overnight.
Old May 29, 2008 | 09:03 AM
PaTKRider's Avatar
would any other damagehappen if i drove around like this for a while and not get it fixed?
Old May 29, 2008 | 12:42 PM
mundy5's Avatar
Like any maintenance issue, prolonged use without correcting the problem can lead to bigger problems. It's always a gamble.
Old May 29, 2008 | 01:02 PM
PaTKRider's Avatar
o ok, any other input on what the nosie may be?
FamousLad
Jul 28, 2009 07:58 PM
kvh
Feb 22, 2008 10:15 AM
addiction2bass
Jul 5, 2007 12:13 PM
domex
Feb 12, 2007 10:24 PM
DingBat
Dec 22, 2005 08:28 PM
