Help with Timing belt replacement.
Old Oct 28, 2009 | 06:47 PM
lcrrick's Avatar
Default Help with Timing belt replacement.
First time poster so please be nice to me, if i step outside the rules.
I am having a heck of a time getting off the crankshaft pully on my 1999 civic LX
I have tried a Air Wrench, then a bigger air gun, then heat and the big air gun... with no luck. PLease help, if you know a trick that can get this off.
Thanks
Old Oct 28, 2009 | 08:30 PM
you mean the big crank pulley nut? air impact should take it right off.
Old Oct 29, 2009 | 05:21 AM
lcrrick's Avatar
I tried a "thunder gun" on it. (the biggest 1/2" impact gun that i can find)
and nothing. does'nt move. more ideas please. I am desperate.
(and yes that is the bolt i am trying to get off, the 17mm bolt that holds the crankshaft pulley on.)
thanks ahead of time.
Old Oct 29, 2009 | 09:31 AM
Connect the gun to the compressor with a short thick hose, and turn the pressure all the way up. You can lose a lot of power in the hose. The curlycue hoses are really bad.
The bolt has conventional right-hand threads. Be sure you're turning it counterclockwise to loosen.
Old Nov 1, 2009 | 09:15 AM
lcrrick's Avatar
Default Still no luck!
Thanks for the tips on the shorter/thicker hose. went and bought a 1/2ID hose 12'. still nothing! More ideas, please.....
Thanks ahead of time
sasquatch
May 25, 2007 04:02 PM
rev2red
Jun 11, 2006 05:54 AM
joshr799
Mar 22, 2006 08:53 PM
hoppyumr
Nov 23, 2005 02:28 PM
jennifert9
15
Mar 7, 2005 10:17 PM
