high beam issues
Old May 18, 2008 | 08:58 AM
I8UMUP's Avatar
Default high beam issues
ok i failed inspection friday due to my high beam indicator does not work so i went stright to the dealer and got a bulb i replaced it and it still does not work so does any one have any ideas on why my instrument cluster light will not illuminate or any ideas on a way i can rig it to pass inspection
Old May 18, 2008 | 10:53 AM
Default RE: high beam issues
Check whether fuse 5 is blown (for 96-00 Civic).
Old May 18, 2008 | 11:53 AM
I8UMUP's Avatar
i have a 92 civic
Old May 18, 2008 | 02:22 PM
you could rig it up to work. but i dont see why it shouldnt work.
maybe a plug has a loose wire. or maybe the copper conection around the plug has came loose or worn off....
pull the cluster and look for any loose copper wire joint spots on the back of the cluster... something like this...
follow that HIGH BEAM bulb location strip and trace it back to where a wire harness conects...
it could be as small as the copper contact has worn a hole in the copper contact point or folded over....
if they look fine then you might have to do some custom wiring. a led, resistor and some wire ran from your highbeam wire off the steering colum to the led and simply put some hot glue or tape to hold it in that hole for the inspection.
Old May 18, 2008 | 02:47 PM
ORIGINAL: I8UMUP
i have a 92 civic
Check whether fuse 10 is blown. Otherwise, check the circuit and ground wire (black) as mentioned by addiction.
blackseries99
Jan 3, 2013 12:27 PM
Fiirkan
Jan 23, 2007 08:52 PM
yamahaSHO
Dec 18, 2006 02:50 AM
jramirez85
Oct 7, 2006 12:25 PM
liliechen
Dec 25, 2005 11:15 AM
