how do you remove camshaft?
Old Aug 8, 2007 | 06:20 PM
noshowallgo's Avatar
Default how do you remove camshaft?
i have a d16z6 i removed the ten bolts at the top f the head what else do i do to access the camshaft?
Old Aug 8, 2007 | 06:42 PM
AgentofDarkness's Avatar
Default RE: how do you remove camshaft?
If you have removed the valve cover, you will also need to remove the timing belt and the camshaft gear. Next you will need to remove the rocker arm assembly. Next, lift the camshaft assembly from the cylinder head.
Old Aug 8, 2007 | 06:44 PM
ej6buddy's Avatar
https://www.hondacivicforum.com/m_372232/tm.htm
Old Aug 9, 2007 | 09:50 AM
im stuck i cant get the rocker arm assembily off or its really tight and i cant pull it out
Old Aug 9, 2007 | 07:52 PM
bump anyone
maddawg
Aug 17, 2005 01:27 PM
Big T
Aug 14, 2005 03:09 AM
WendyBlu
Jun 29, 2005 08:18 PM
joypeddle
Oct 16, 2004 07:57 AM
03civiclx
May 24, 2004 01:51 PM
