ICM wiring
Old Jun 3, 2009 | 06:35 PM
Any ECU codes?
If the fuel pump primes but you lack spark, then check the coil. You can do this at home with a multimeter. If the coil is fine, check whether the timing belt snapped.
If you have fuel and spark, check whether the timing belt slipped.
Old Jun 5, 2009 | 10:39 AM
drumforever's Avatar
No codes and pump is priming. How do I use a multimeter to check the coil?
Old Jun 5, 2009 | 10:42 AM
Do you lack spark at all four plugs?
Old Jun 5, 2009 | 11:13 AM
I don't have anyone around to help me check for spark right now. Is there some way to check by myself?
Old Jun 5, 2009 | 11:55 AM
Nobody around to just turn the key?
Otherwise you'll need to turn the key to ON(II), wire the starter solenoid to the battery, and quickly check spark -- this would be tricky though.
Old Jun 8, 2009 | 03:50 PM
Ended up being the coil. Thanks for all your help.
trustdestruction
Jul 2, 2009 09:11 PM
crazyflippindude
Oct 29, 2008 09:28 AM
GAMBOA
14
Nov 23, 2007 01:59 PM
honda_farmboy
20
Aug 7, 2007 05:29 PM
billthepill
Jul 14, 2005 01:49 PM
