idle problems, REALLY NEED HELP!!!!!
Old Feb 20, 2009 | 07:50 AM
Ghest4x's Avatar
Default idle problems, REALLY NEED HELP!!!!!
What's up everyone,
I have a 90 civic 1.5L. I'm having an idle problem that's driving me crazy. Car runs fine but when I'm waiting at a stop light the idle tends to drop to about 500 rpm's and at times it stalls out. This only occurs when the engine is warm. If I hit the throttle the problem stops for like less than a minute and then it starts acting up again. When it dies i can turn it back on with no problems. Some forums have suggested checking and or replacing the tps sensor. Does anyone know what my problem might be? Could it be a vacuum issue, maybe my fuel vapor canister? Oh and i am not getting any engine codes, whatever the problem is it's not being detected by the ECU.
If anyone can help me please write back. I appreciate it.
Old Feb 20, 2009 | 08:03 AM
Usually this problem is a sticky idle air control valve, which is mounted on the intake manifold near cylinder #1. Unbolt the valve and clean the air passages out with carb cleaner.
Also check the ECU for any trouble codes. You do this by looking at the LED mounted on the ECU itself, which is under the carpet on the inside of the firewall where the passenger's feet would go.
Old Feb 20, 2009 | 08:06 AM
mcmichael13's Avatar
you might wanna replace the FITV (fast idle throttle valve).
Old Feb 20, 2009 | 09:37 AM
Ghest4x's Avatar
Thanks for the help. I appreciate it. As soon as i get home today i'll check that out.
chasemclemore
16
Sep 25, 2009 12:16 PM
krystencivic99
Jan 21, 2008 12:09 PM
Partizan
Jan 25, 2007 09:13 PM
InfinityBPS
Jun 27, 2006 09:35 PM
DeiblerDelux
Jun 9, 2005 11:53 AM
