Idling Problem
Old Sep 10, 2008 | 10:19 PM
94hondacivicEX's Avatar
Default Idling Problem
I finally got my EG running and now i have idling problems the car starts up an idles up to 1800rpms and then begings to surge shortly after im thinkin its in the iacv any other suggestions if thats not the case the problem causing it not to run has nothing to do with the situation so any hints might help my day smother tommorow when locating the problem thanks by the way in a 94 d16z6
Old Sep 11, 2008 | 05:10 AM
Also:
1) Check and clean the fast idle valve on the throttle body
2) Look for intake air/vacuum leaks
3) Bleed the cooling system of possible trapped air
Old Sep 11, 2008 | 05:37 AM
Another possibility is the throttle cable too tight, holding the throttle partway open at idle.
Take the air intake duct off of the throttle body and note there are several holes in the side before the throttle plate. The one on the bottom supplies the fast idle valve. The one on the back goes to the IACV. You can block those with your finger and see if the engine slows down. If no air is going through those normal bypass paths, it must be leaking in somewhere else. A vacuum leak anywhere will cause idle speed to increase out of control.
Old Sep 11, 2008 | 11:09 AM
ok ill check them at school and let you know how that goes thanks guys
Old Sep 12, 2008 | 03:31 AM
Also check the TPS voltage
VinceDee
Jun 21, 2007 04:09 AM
blackmetal619
May 15, 2007 08:48 AM
soprano19
May 10, 2007 04:02 AM
bleedhondos
Dec 18, 2005 03:29 PM
tamda00
Sep 18, 2005 06:50 AM
