Ignition switch
Old Apr 21, 2008 | 02:11 AM
98civicnewbie's Avatar
Default Ignition switch
I just bought a civic, first honda, it is a n LX with a manual transmission. Everything was fine until this morning I tried to start it and the ignitiobn key would not turn.It will only move a little back and forth. Any Help would be appreciated. I am unsure whether it is the switch or something with the steering wheel lock. Thanks
Old Apr 21, 2008 | 10:52 AM
mundy5's Avatar
Default RE: Ignition switch
sometimes, you need to move the steering wheel left then right then left until the steering wheel lock gets disengaged while you try to turn the ignition.
It's some kind of safety mechanism. It only happens when you lock the steering wheel after you turn offthe ignition.
Old Apr 21, 2008 | 11:02 AM
burnindesirez02's Avatar
What mundy5 said sh ould work. Mine does that alot. My ignition though is screwed up because i can't fit my key all the way in or i can't start the car it has to be brought out a little in order to turn the ignition. hope this helps
danomatic93
Routine Maintenance DIYs
Jan 15, 2012 07:16 AM
dartax
May 29, 2010 08:22 PM
bceja10
Oct 4, 2006 02:14 AM
b3651
Sep 24, 2005 09:46 PM
aredecomm
Jun 6, 2005 03:11 PM
