L.e.d screws
Old Sep 16, 2008 | 07:37 AM
jrestrepo589's Avatar
oo i kno that..trust me im not dat much of an idiot..lol
it just doesnt work wen the doors are open..its probably like u said..ima check the doors pin switch and if its not that then its one of the wires..so ima check that...
Old Sep 16, 2008 | 09:05 AM
not callen ya stupid... but ya never know when someone will overlook a tiny detail.
like all the people posting about there dash lights being to dim.LOL they didnt know they had a dimmer switch on the dash.
Old Sep 16, 2008 | 12:42 PM
Originally Posted by jrestrepo589
by the way..anyway i can have these turn on only wen my doors open...
p.s: my dome light already doesnt turn on wen my door is open..i dont kno why
does the dome light work whenever you open any of the doors? or does it just not turn on when you open the driver's door?
The problem is probably that the little door switch is corroded. Carefully remove the door jam dome light switch from the door jam, take it apart, and clean out the inside contacts of the button's slider thing.
To make those other lights turn on when the door opens, you have 2 options:
1. If you want the lights to come on when you open a door, you must wire the switches to a constant 12V power source (fused) and then run the ground wire to every door jam switch. To make it only come on when you open a certain door, wire them to that door's door jam switch.
2. If you want them to turn on both when you open the door and also when you turn the dome light switch manually on, you must wire them directly do the dome light.
Thefbomb13
May 31, 2007 04:51 PM
98civicsedan
Feb 4, 2007 09:55 AM
POLYTHING
Dec 18, 2006 10:17 PM
pWnEdU
Jul 18, 2006 06:28 PM
Cleft_Asunder
Jun 27, 2005 03:52 PM
