lights on dash panel
Yes they're replaceable, but you'll need to take the panel out of the car first. The panel bulbs are on the same circuit as the speedometer, etc. backlight. If your speedometer lights up normally, the bulbs in the HVAC panel are probably simply burned out.
The ones on the buttons are LEDs so they pretty much never go out.
yup, they are blown. it's a pain to replace but worth it to be able to see in the dark. I believe its 2 or 3 bulbs in total. you need to access them from behind the control unit which means you need to remove it. go to my signature and download your yr's service manual. it gives you all the details you will need to do this job.
itzcorky
Nov 13, 2013 06:26 PM
itzcorky
Sep 21, 2011 07:45 AM
joeD2J
Apr 3, 2011 02:18 AM
stnhbrsurfer16
Jan 6, 2011 03:59 AM
PredatorCoder
Aug 15, 2005 05:43 PM
