a little blue smoke
Old Apr 2, 2011 | 10:20 PM
akceltdog's Avatar
Default a little blue smoke
just bought a 93 DX with 127,000, and it blows a little blue smoke......also have a 94 LX that has 234,000 and a new top end, runs great, but don't know how long it's going to last....can i swap motor tranny if necessary?....just wondering if i should just fix the 93 (blue smoke)....and sell the 94, ......the 93 DX has better interior, body, and suspension.....how much to fix the smoke?, does this mean the motor is junk?...help!
Old Apr 3, 2011 | 04:37 AM
You have exactly the same engine and transmission in both cars, so it would be easy to swap.
Old Apr 3, 2011 | 06:59 AM
akceltdog's Avatar
Default swap
thanks.....is that something i could do in my driveway?
Old Apr 3, 2011 | 07:18 AM
Probably is.
Go to hondatech.info: Honda service manuals and look for the Civic manual. It's in PDF format and will outline the whole process, as well as tell you what tools you need.
(You might try throwing a can of a product called Restore in the engine. I would guess your rings are a little worn, hence the blue smoke. Restore will help with that.)
Old Apr 6, 2011 | 03:20 AM
Mecca8383's Avatar
I thought white smoke was for a blown headgasket & blue was for oil being burned somewhere...?
Old Apr 6, 2011 | 04:40 AM
Originally Posted by elperdido
Blue smoke is usually the sign of a blown headgasket, or a head gasket that is going out. I would just fix the gasket and keep the car since it has a fresher motor.
Actually, that's white smoke. Blue = oil, white = coolant. Blown head gasket = coolant getting into cylinders = white smoke. Blue smoke = oil in the cylinders from worn rings or bad valve seals.
ding-ding-ding
tweedy17
Feb 27, 2012 10:06 AM
staffbuoy
Oct 17, 2007 04:22 AM
vektor
Jun 17, 2007 07:20 PM
stevie b
Jun 6, 2007 04:37 PM
honda_tuner90
May 18, 2007 11:11 AM
