Loss of power in 3-5 gears
Old Mar 3, 2010 | 04:47 PM
TexasAir's Avatar
Default Loss of power in 3-5 gears
I recently purchased an 87 Honda CRX HF. The car runs great in 1st and 2nd gear and the engine will turn 6,500 rpm. When I shift into 3rd, 4th, and 5th gears and try to accelerate hard the engine will bog down. If I back off and accelerate slowly the car will slowly start to accelerate and I can finally get to 70 mph. The car has no power going up steep hill and I have to down shaft to 2nd gear and 30 mph to get up the hill. Any ideas what is wrong?
Old Mar 3, 2010 | 04:56 PM
Your clutch is slipping if the rpm go up but the mph do not.
Old Mar 3, 2010 | 05:05 PM
TexasAir's Avatar
The clutch is not slipping. The mph goes up as the engine goes up. The engine rpms will not go up under hard acceleration in 3rd-5th gears, it acts like it is starving for gas but the car does not have the problem in 1st and 2nd gear.
Old Mar 3, 2010 | 05:53 PM
02Hatchback's Avatar
possibly vacuum leak
Old Mar 3, 2010 | 05:59 PM
If the system is PGM-FI, then check for a trouble code:
D17Punk
Nov 9, 2007 11:06 AM
SI_smiley07
Aug 10, 2007 02:39 PM
rzimmer11
Mar 15, 2005 11:32 PM
islandguy
Oct 23, 2004 01:20 PM
jjgarcia
Aug 2, 2004 10:26 AM
