motor mount issues
...all of the mounts are designed to control and dampen engine movement. there are 2 mounts, the engine torque(the one phillip mentioned) and transmission torque mounts that reduce vibrations, engine movement and controls torque output the motor produces under acceleration. this is why inserts such as the ones Energy Suspension make reduce wheel hope a good amount due to less energy being lost within the mount. like i said, replacing that mount, with an OEM mount, may reduce wheel hop just a little bit.
Yea Aj's right but that lower drivers mount is a honda problem. I recently fixed mine during a boost project. By fixed, I mean, fill it in with 3m window weld. It is a polyurethane fill that is pretty much the same as motor mount inserts. The only problem is that it takes 2 days to cure. I can get pics if you want, but if you do all motor mounts with the 3m or even with inserts, you will notice a lot more vibration in the cabin.
kstich
Feb 9, 2008 07:40 PM
