NEED HELP ASAP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 96 HONDA CIVIC
Old May 29, 2006 | 05:19 PM
PhBsCivic34's Avatar
Default NEED HELP ASAP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 96 HONDA CIVIC
OK So I put n a new complete ignition system for a 96-00 Honda Civic With 2 keys, because My key was getting stuck and I was told to put the new one in i also put it in because i lost the only set of keys i had to the car so i put this in. But Im still having the problem I was having because where my key gets stuck when i turn the car off and i can't get it out! but heres the funny part I have to pop the hood and take the battier termenal off the postive and then the key will come out and then I can put it bac on and redo the process everytime i go anywhere some one PLEASEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE help me Its driving me Nutts.
Thanks
Mat
Old Jun 1, 2006 | 06:01 AM
BoostEK's Avatar
Default RE: NEED HELP ASAP PLEASE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 96 HONDA CIVIC
There's a little metal tab that locks your ignition in place so you can't take the key out. When you disconnect the battery, it releases the little solenoid. Look for a blown/damaged fuse, cut/crossed wires in the area around the steering column, etc.
Old Jun 1, 2006 | 08:01 AM
gwl's Avatar
gwl
If your car is an automatic, I would check around the shifter area because you can't pull the key when it is not in the park position.
kingola420
Apr 14, 2010 01:39 PM
ryan69
Jan 9, 2007 10:49 PM
sbowers
Nov 5, 2006 02:59 PM
soldout712
Oct 30, 2006 04:03 PM
Jeremy102579
Oct 3, 2005 03:16 PM
