Need help, front driver side squeaking
First let me say that I have replaced the struts, sway bar bushings, and upper control arm bushings along with upper ball joints within the last year or so. I checked all bolts/nuts and all are tight.
I've had this new noise for a few days, figured it might go away, but it keeps recurring.
The sound comes strictly from the front drivers side, near the lower ball joint/hub area.
-If I turn the wheel, sometimes it squeaks
-If I bounce the left side of the car it squeaks
When installing my struts I did tear the drivers side lower ball joint, but had some energy suspension ball joint boots handy, greased them up and installed the cover. The ball joint cover still looks good. So I'm assuming this is not a problem.
The tie rods have no tears in the boots and when I try to move the wheel by hand and there's no play, so I'm assuming this is not a problem.
There is no grinding or clunk, just a squeak that I can hear mainly when I'm idle. Sometimes I can hear it at low speeds while turning and it seems to squeak on the initial movement of the steering wheel. The noise does not occur if I turn the wheel after half rotation, but it squeaks turning either way.
Thanks for any help
Thanks for any help
civicrevolution
Apr 3, 2011 04:27 PM
therivler1
Jan 15, 2007 03:54 PM
Naudlee
May 26, 2006 09:44 PM
luilui
Nov 17, 2005 10:29 PM
