need some help
Old May 10, 2008 | 05:48 PM
egsedanguy's Avatar
Default need some help
ok as most of you know i am working on a 93 civic sedan. i have the stock lx engine in it wright know. In my garage is a b18a1 out a 93 teg. it has the harness on it with everything else. dizzy throttle body etc. what motor mounts do i need to use????? ecu. ya i have the stock one for lx, what do i have to do to it to use it??? do i need one from a obd1 integra??? what do i have to use from my lx harness to make the obd0 ls into a obd1???? and the axels, do i use both from the stock b18 engine?? and any body got this stuff lying round let me know. o and a nice clutch and fly. those are the main things holding me up wright know from at least getting it in the car...so the skinny of it is... what mounts, ecu, harness info, axels, obd conversion?????
Old May 10, 2008 | 06:56 PM
hatch46580's Avatar
Default RE: need some help
the only thing about the mounts is you need to use the integra rear tranny mount the rest use stock ones.pretty surecant use the lx ecu. you would need the p28p72 p75p61. use the stock axles from the b18. and you will needa obd1 teg dizzy. the harness you use the stock one in your lx.
and i dohave a obd1 dizzy and complete wire harness from a 95 integra..and yu need to remove the b18 injectors and replace them with your lx ones
If any of myinfo is wrong please correct me thanks.
Old May 10, 2008 | 07:06 PM
hatch46580's Avatar
brain fart......the 93 intega is obd1.
boobeyes
Jan 20, 2012 12:51 PM
PineappleMan
Feb 24, 2010 03:38 PM
joelmatt89
Jan 26, 2009 06:08 PM
dfdon
Aug 15, 2007 03:39 PM
CivicCrazy
Nov 29, 2004 11:50 AM
