need suggestions, for non-running car
Old Oct 23, 2008 | 08:47 PM
91spedhatch's Avatar
Default need suggestions, for non-running car
ive got a 91 civic hatch. its a dx, recently i did a multi point conversion, so basically its a 1.5 si. but i was on my way home the other day, and she threw a couple of codes, 16 and 22, but i dont have vtec. possible things ive heard were, resister box, all of the injectors might have taken a ****. ecu has an isssue. i havnt found any damaged wires, under the hood. when she took a **** i sat on the ignition and she started, but would not idel on her own and died again. i havnt gotten her stared after that. so if suggjestion. oh also i hvnt checked if the timing belt jumped a tooh but would that make her die? let me know... thanks!
Old Oct 23, 2008 | 11:53 PM
94hondacivicEX's Avatar
i would say check the time for sure then if its starting consider the fuel pump make sure all fuses are good burnt fuses help indicate where the problem lies kinda sounds to me like the fuel pump if you did the multi injector conversion maybe the pump couldnt handle make sure your spark is good generally being of time it still runs but just ****ty it depends just check those few things and your boungd to find something out possibly do a compression test also
Old Oct 27, 2008 | 05:10 PM
aight that does help and ill check those, as soon as i can. THANKS
new2honda
Aug 21, 2014 05:49 PM
giwatcher
Feb 14, 2009 09:14 AM
Kw8z3bOi
Apr 8, 2008 08:51 PM
jad1217
Apr 9, 2006 04:25 PM
Esquirrel
Mar 18, 2006 06:53 AM
