new start problem
Old Jan 21, 2005 | 04:09 PM
triggerstep's Avatar
Default new start problem
sorry to continue on the same stuff,but now when i turn the key and hold for 10 count then just completly let go of the key car will start.I really dont have to much money so i really need help with this please.
Old Sep 29, 2006 | 08:19 PM
Lordnismo's Avatar
Default RE: new start problem
Check for short in the ignition or try letting your key set in the on position for a few secs then start it.
Old Sep 29, 2006 | 10:14 PM
sillyredcivic's Avatar
what I do is let it crank for a sec or two, then let off and then let it crank and mine usually kicks over like that pretty consistently, however if I hold the key to crank it will crank for like ten seconds also. Try the crank, pause crank routine and se if that helps, I also noticed it started happening after I changed my wires, of course I went with super cheap autozone brand so it probably explains a thing or two but anyway, try my trick and see if it works for you
Old Sep 29, 2006 | 10:38 PM
AgentofDarkness's Avatar
ORIGINAL: Lordnismo
Shorts blow fuses.... Anyway, what happens when you turn the key? Does the starter turn the engine over but the car doesn't start? I would look at the fuel system. Pull the plug wires and have someone turn the engine over. Check for spark. If there is spark, your problem will most likely be with the fuel system.
Michae1
Mar 6, 2014 04:29 AM
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
Tealingston
Dec 31, 2008 08:48 PM
Ronin Inc
EG Swaps
Jul 10, 2008 06:29 PM
