No Heat In Cabin
Old Feb 17, 2007 | 01:03 PM
sbg20307's Avatar
Default No Heat In Cabin
I replaced the water bypass hose in my 1999 Honda Civic EX Coupe. Unfortunately, I used a generic silicone hose and it sprung a leak. All kinds of coolant sprayed out and the car overheated a bit.
I've replaced the water bypass hose and that seems to be working, but there is no heat coming out of the vents into the cabin. The air coming out of the vents is cool, but there is air coming out. The coolant level is filled to the max. I did let the car idle for 5 minutes and then refill the antifreeze to the right level. I did try idling with the radiator cap off to deal with an air pocket, but that doesn't seem to get the heater going.
How do I get the heater working again?
Old Feb 17, 2007 | 01:36 PM
INJENalltheway's Avatar
Default RE: No Heat In Cabin
Is it really hard to move the temperature setting lever?
Old Feb 17, 2007 | 01:50 PM
sbg20307's Avatar
There is no trouble moving the temperature dial. I turn it up all the way to the hottest setting, but after 5-10 minutes there is still no hot air.
Old Feb 17, 2007 | 01:51 PM
And you only had the problem after you replaced the hose?
Old Feb 17, 2007 | 02:11 PM
sbg20307's Avatar
Yes. The problem happened after the water bypass hose busted and sprayed antifreeze all over. I was mostly concentrating on watching the temperature to make sure the car didn't overheat. Now that the overheating problem seems to be resolved, I'm noticing that the heater doesn't work. I think the problem started when the car lost so much antifreeze.
Old Feb 17, 2007 | 04:54 PM
fglaustin's Avatar
sounds like the thermostat stuck open.
take it out and put in a pan of water and boil it - can tell when it opens.
use a thermometer to see the temp that it opens
if it is open when you take it out, then replace it (assuming you left the engine cool down)
Old Feb 19, 2007 | 12:26 PM
sbg20307's Avatar
thanks for the responses.
i was just being dumb and i had lost a lot more antifreeze than i thought i had. after several cycles of filling up the radiator and starting the car, i finally got enough antifreeze into the cooling system to get the car running well. after a few mintues of idling, the heater was working again.
maachan513
Jun 12, 2007 01:23 PM
Vipergal_1
Mar 18, 2007 01:53 AM
cderalow
Nov 25, 2006 02:43 PM
Auto98EX
Aug 15, 2005 02:04 AM
