No Heater Blower
Hi my first post.....
Hello Everybody!!!!!
I've got problems with the missus 53 Honda Civic Sport 1.6 VTec.
The Heater Blower has packed in, I've checked the air condition fuse and the LAF fan fuse, all ok.
Any ideas?
Supply battery power directly to the motor. If it runs, then you likely have a bad motor relay or fan switch.
When the A/C button illuminates, is the A/C compressor activated? If not, then the button switch that turns the light ON is faulty. Can you remove the button in an attempt to identify the lighting problem?
Thanks for the advice I'll try supplyingpower direct to the blower.
The A/C switch has the illumination built into the switch. When I turn the ignition on the A/C is illuminated, I press it andthe illuminated switch goes out (the A/Cdoesnt work at the moment), much later the A/C will become illuminated again for no reason.
Deviant56
Jan 3, 2011 12:04 PM
Oldvic
Jun 20, 2007 12:52 PM
