NO POWER!! Please help
Old Mar 28, 2014 | 02:26 PM
drebin989's Avatar
Exclamation NO POWER!! Please help
Ok this is a long story but, I have a 94 honda civic del sol. The chassis is a b series but I have rebuilt a d15 for it. I have a problem with the power, there is nothing. No lights, no clicking, no radio, nothing. We know the battery is good and all the negatives are connected. This issue originally started with a non vtec harness, (motor is not vtec) but ive changed the harness. when it started it had no power then it would randomly turn on if left for 10+ minutes but the minute you turned the key it died. This happened 2-3 times before it cut out. We replaced the under the hood fuse box and nothing, all fuses (hood/cabin) are good. All the wiring is right and the negatives are all on.
the only thing we can think of is the ignation switch is bad. and heres my question, does anyone know how to test that theory or have any other ideas?
please let me know, thanks.
Old Mar 28, 2014 | 04:38 PM
Do the headlights work? If not there is no power on the main power / ground circuits from the battery, since the headlights don't go through the ignition switch.
Do you have a voltmeter? It's essential for this situation since you can't see electricity.
Then you could take the column cover off and probe for voltage going in and out of the ignition switch.
Another test is to pull the brake handle up and watch the brake warning light when you turn the key on and off. It should be on in the on and start positions. It is connected to the same circuit from the key as the ignition.
But really this situation calls for going through the circuit step by step using a schematic and a voltmeter.
Old Apr 4, 2014 | 10:15 AM
drebin989's Avatar
there is no power at all, with or without the key, the flashers dont work, nothing at all, i will test and post later, any ideas currently?
D16racerchick
Jan 3, 2008 05:15 PM
snosurfa7
May 5, 2006 08:21 AM
Honda99Civic
Apr 20, 2006 10:13 PM
nwhite82
Feb 9, 2005 11:01 AM
civic1.5uk
Nov 28, 2004 07:29 AM
