No spark, no fuel after head replacement
Old Dec 20, 2008 | 06:26 AM
Don't junk your Civic for a no-start problem!
Do you hear the low humming noise of the fuel pump priming for 2 seconds when you turn the key to ON(II)?
Do you have a fuel injected or carbureted engine?
Have you replaced the igniter unit in the distributor?
Carefully clean and tighten all of the ground wires (see last diagram below).
Old Dec 20, 2008 | 11:28 PM
stcivicthegreat's Avatar
itinerant-
No worries, it will never go to the scrap yard (I can't remember why I said that!)
I thought about the spark plug wires themselves. I am thinking that bad wires would at least send SOME spark. But I am getting NO spark at all. Maybe I am wrong?
RonJ-
Not sure about the fuel pump, I will make sure and check that. I don't think I heard it.
The engine is FI. Thanks for the diagrams. The igniter was replaced with the distributor was.
The grounds...this is interesting because this stuff could have moved around. I will look at these very carefully...
Thanks!!!!!!!!!
Old Dec 21, 2008 | 08:08 AM
The ground wire attached to the thermostat housing is exceptionally important. Corrosion, looseness, and disconnection is a common cause for a no-start condition.
As mk mentions, you should also see whether the ECU is throwing any codes:
martinc98
Dec 6, 2013 07:30 AM
dylank
Aug 7, 2013 07:59 AM
always workin
Jun 19, 2013 06:08 PM
jonsaidthat
Oct 30, 2008 05:04 AM
lvo civic
Mar 16, 2006 12:43 AM
