No Start / No Spark / No Signal To Coil
Old Mar 19, 2008 | 02:35 PM
mlech's Avatar
Default No Start / No Spark / No Signal To Coil
Hi all -
My 96 civic ex died and doesn't give spark. No spark at the plugs.. so I checked the coil ... no spark there either. The coil tested at the very top of the a-b range at autozone (.8 ohms). I went through the a number of coil and ICM tests per the manual and this nifty site: http://techauto.awardspace.com/ignition.html
From the tests I learned that voltage is getting to both the coil and ICM with the iginiton on. However ...the ICM isn't giving the coil any signal when the engine is cranked. The voltage from the ICM to the coil goes dead when cranked.
Timing belt is on. Fuel and relay kick in. CEL light behaves correctly. So my question is .....should I:
a) replace the ICM?
b) replace the entire disyributor? or
c) bring it to a mechanic for additional testing?
I don't want to spend needlessly on parts... would rather save that for gas.
Thanks for help solving the mystery.
btw - great forum.. learned a bunch already.
Old Mar 19, 2008 | 02:37 PM
95civic1.6l's Avatar
Default RE: No signal from ICM to coil
I had a problem with my ignition coil and it was going to cost almost as much as getting a rebuilt one.
Old Mar 27, 2008 | 01:28 PM
mlech's Avatar
Finally got my ignition control module from Rock Auto. Popped it in and she started on the 1st crank . $60 and 10 minutes of work. YES!!!Sure beats putting in a new distributor.
Old Mar 27, 2008 | 02:52 PM
Do you have steady voltage on the other wire on the coil, the one that doesn't go to the ICM, while cranking? If it drops to zero too there is a problem with the car's wiring.
DaCivicman
Jul 3, 2014 03:35 AM
apfing
Sep 28, 2010 05:16 AM
dnascuba
Apr 23, 2008 01:04 AM
glenbo72
Apr 22, 2008 05:53 PM
glenbo72
Mar 13, 2008 09:00 PM
