overheating
Old Jul 10, 2009 | 07:41 PM
Hondacivicbullet96's Avatar
Default overheating
Hey everyone,
im new to the forum and ive been seaching high and low for some help before i spend a fortune!!
i have a honda civic automatic 1996, when i was on the freeway it started to get hot. the radiator was flushed and cleaned (its actually a fairly new radiator) and we got a new thermostat.
it only seems to get hot when it goes over 100kms - so ive been driving like a grandma on the freeways
could it be the transmission or could it just mean my water pump might need replacing???
i desprate for help!!!
thanks everyone
Old Jul 11, 2009 | 02:34 AM
SPLAT's Avatar
The trans would have nothing to do with your car overheating, the best bet would be the water pump.
Old Jul 11, 2009 | 08:57 AM
Are you losing or burning coolant?
Does the heater work?
Have you tried bleeding the cooling system?
Old Jul 11, 2009 | 11:20 PM
thankyou for replying
my heater works well
the radiator was flushed and fully cleaned, it doesnt seem to use all the coolant and my reserve has stayed normal- no less has gone
it makes no noise when it starts to over heat,- but i do have to put water and coolant in when it does start to over heat.
its fine if i drive at 100 but anything over and im talking 105 it gets really hot.
Old Jul 12, 2009 | 05:50 AM
burnindesirez02's Avatar
they could have always sold you a bad thermostat that is stuck closed....
Old Jul 12, 2009 | 08:46 AM
Flushing is different than bleeding. Did you bleed the cooling system of possible trapped air?
Old Jul 12, 2009 | 09:26 AM
if you didn't bleed the system it could do that and Honda hate air in the cooling system...
Old Jul 12, 2009 | 02:13 PM
churritos567's Avatar
from the sound of adding water in the coolant when it starts to overheat sounds like a hose is ripped did you cyheck your hoses?
Old Jul 12, 2009 | 02:23 PM
conceptualpolymer's Avatar
Also, a bad radiator cap won't hold pressure, but typically, the antifreeze will boil out the reservoir at some point. A cylinder head gasket leak could raise coolant temps and a radiator shop or auto repair garage can test the coolant to see if combustion gasses are getting into it.
You mention 100 kms; that's way faster than a Bugatti Veyron's top speed, which is about 250 MPH.......
trebor_2005
May 19, 2006 01:40 AM
Wooz
Apr 26, 2005 10:04 AM
9toes
Jan 28, 2005 01:43 PM
sonscivic
Jan 4, 2005 06:16 PM
Civic95Blue
Jul 29, 2004 10:09 PM
