PCM/ECM 02 civic
Old May 21, 2008 | 02:48 PM
matt701's Avatar
Default PCM/ECM 02 civic
I'm starting a new thread to see if anyone can help with this topic. The cause of my AC issue is a bad PCM. My paperwork from the dealer says PCM/ECM, is this 2 seperate items or just different name for the same unit? Also, does anyone know what the part number is? I have the 1.7L vtec motor, EX manual transmission. I worried about the programming after install, but I see Ebay has some ECM's with chips in them for programming, is this what I need? This is a new area for me, but I'd really like to learn as the dealer quoted me at $750 for just replacing the PCM/ECM and I think there's an additional charge for programming it.
Matt
Old May 21, 2008 | 02:57 PM
Default RE: PCM/ECM 02 civic
I think you just need a stock replacement ECM/PCM (single unit), with no chips or programming required to my knowledge.
Look here:
http://www.hondaautomotiveparts.com/
When you know the precise stock part name/number, then compare prices on eBay.
Old May 21, 2008 | 03:14 PM
matt701's Avatar
The dealer wrote on my sheet "All keys will need to program so ECM can see the keys", thats the only reason I thought something had to be programmed. Thanks for the link, that should narrow down which part I need.
Old May 21, 2008 | 03:32 PM
Not absolutely sure, but I think the key programming you mention is done through the key rather than the ECM.
Old May 21, 2008 | 04:11 PM
matt701's Avatar
I just don't want to get the ecm installed and not be able to start the car. Can I program the keys to the car myself?
Old May 21, 2008 | 04:42 PM
ORIGINAL: matt701
Old May 21, 2008 | 04:56 PM
matt701's Avatar
That should get the remotes working, but I believe the transponder ID's for the keys themselvesare stored within the ECU or immobilizer unit. I dont know if this is something I can clear using a scanner or if the only option is going back to the dealer.
Old May 21, 2008 | 05:16 PM
Old May 21, 2008 | 06:11 PM
matt701's Avatar
Thanks again RonJ for the diagram. I guess I'll buy the ECM and see what happens. Hopefully I won't have to go back to the dealer or be towed back.
b4ked20
Mar 4, 2013 04:45 PM
hellobd
Apr 7, 2012 10:04 AM
00hondacivicsi
Jan 15, 2010 09:34 PM
zwj1021
Aug 7, 2008 07:36 PM
swimalee
Mar 12, 2005 10:01 PM
