Please, Please, Help!! - Civic Won't start
Check for 12 volts at the following points:
Pin 7 of main relay, yellow/white wire. Constant from fuse 31 in underhood box.
Pin 5 of main relay, black/yellow wire. When key on, from fuse 24 underdash.
Distributor black/yellow wire. When key on, from fuse 15 underdash.
ECU pin A25 and B1, yellow/black. When key on, from main relay pin 6.
ECU pins A1, A2, A3, and A5. From fuel injectors. Should power up when key is on.
Pin 2 main relay, blue/white. When starter engaged, from fuse 18 underdash.
Pin 4 main relay yellow/green. Feeds the fuel pump. Should come on when starter engaged or upon ECU command for 2 seconds after key on.
If all these pass and the grounds are good, your ECU is likely bad.
David_S
Oct 24, 2013 10:06 AM
Liddy-b
Jun 23, 2011 10:44 AM
ATGdrummer
Nov 2, 2010 06:34 PM
shadman52
Nov 28, 2007 05:25 PM
eclecticanna
Dec 13, 2005 10:21 PM
