PO8-5 on a 97 lx help
Old Nov 12, 2008 | 12:02 PM
blazz's Avatar
Default PO8-5 on a 97 lx help
I put a PO8-5 head that came from a 94 SI [I think] on my 97 LX,
But my 97 distributor did not bolt up!!
If i can find the right distributor for the PO8-5 head and re-wire it,,, will it work?
If not i will have to fix my old LX head and put it back on it leaks PSI back into the intake. When you turn it by hand you can here it coming out the intake, But now that i have the head off the valves look ok,[what should i look for?]
Plz help!!
Old Nov 12, 2008 | 01:04 PM
Were the valves properly adjusted on your old head?
Old Nov 12, 2008 | 01:39 PM
blazz's Avatar
I think i did it right, i used a filler gauge b4 all this to check/adjust them, it helped some but did not fix it..
Old Nov 13, 2008 | 11:27 AM
blazz's Avatar
SO...I put the LX head back on..
The car ran good on the test run, but b4 i got back home it started to run funny, at low RPM's it had no power and run ruff,, but when it got up to 3-4k RPM"s it ran strong,
I checked it with a timming light and it was off,
So i fixed that,,But same thing runs ruff mostly starting in 1st gear and at low RPM's
stevenc
Jun 25, 2008 09:57 AM
redridinhood
Oct 9, 2006 07:27 PM
superballa22
Sep 18, 2006 05:06 PM
coolguy1234
May 7, 2006 08:31 PM
Jas10hon
Jul 4, 2005 10:35 PM
