popping noie
Old Sep 3, 2008 | 09:12 PM
a553487's Avatar
Default popping noie
Civic Coupe 06......When I reverse and turn the wheel I hear a popping noise in my car. When I come to a stop, switch gears and drive off Ill come to a quick stop and again lll here the popping sound. When I drive off afterwards and brake there is no sound
Old Sep 3, 2008 | 09:16 PM
jpnolan's Avatar
use the search feature this question has been answered a couple times. normally its the cv joint
Old Sep 4, 2008 | 05:23 AM
Put the front end on jack stands. Crawl under the car and inspect the inner and outer CV boots of both front axles. Also grab the axles and check for excess free play. If bad, normally it's best to just replace the entire axle.
Old Sep 4, 2008 | 06:09 AM
a553487's Avatar
And the brake noise?
Old Sep 4, 2008 | 06:13 AM
All the sounds may be coming from a bad axle(s).
Old Sep 4, 2008 | 06:19 AM
a553487's Avatar
Ill get it checked out. How long a job is that?
Old Sep 4, 2008 | 09:43 AM
c3o5nnect's Avatar
CV joints are a DIY if you've spent anytime working on suspension... You'll will get a dirty doing it with all the grease involved. Expect a few hours to get it done.
tarboroheel1
Sep 22, 2006 08:50 PM
ncpot
Aug 24, 2006 07:53 PM
Ben
Aug 7, 2006 12:43 AM
Dezrat
Aug 5, 2006 05:55 PM
Ei8
Apr 25, 2006 04:04 PM
