Problem after problem
Old Nov 22, 2010 | 07:56 AM
Slammed98silvercoupe's Avatar
thanks for the reply, its the D16Y8.
Old Nov 28, 2010 | 01:00 PM
91crx_83's Avatar
Ok so I looked in my engine bay and did not find any plugs that looked like that except the dizzy but I dont think thats where tose go to also I have the B16A2 engine in mine sorry I couldnt be of more assistance
Old Dec 16, 2010 | 07:08 PM
91crx_83's Avatar
Ok so I am correcting myself from Im going to guess you have a manual trans and if so those 2 connectors prob go to an auto tran but sense you dont have that they are supposed to be disconnected, I found this out while trying to figure out what I bent when I had an incident where I had to curb check my car and found thoses on the back side of the engine. The way they saved money at the factory was to use the same harnesses for both man and auto trans I had a 99 Neon that had a man tran but utilized a flexplate instead of a flywheel but those were only produced from the Ill plant the mexico plant still used the flywheel and flexplate depending on the trans
Old Dec 19, 2010 | 05:08 PM
well that makes sense, since my car still runs ok. I guess they are for the auto trans. Thanks...
Old Dec 19, 2010 | 05:16 PM
If you reset the ECU, do the same codes return? If not, ignore them.
I think those are just two blind plugs where one power wire supplies voltage to numerous components.
classiccarsrule85
22
Mar 31, 2008 05:14 AM
MarcB
28
Jan 28, 2007 01:52 PM
molsen81
Aug 27, 2006 11:28 AM
redcivic93
May 26, 2006 07:13 PM
gambino
Nov 21, 2005 02:53 AM
