problem with my ef
Old May 13, 2009 | 12:10 PM
jrobs_ef's Avatar
Unhappy problem with my ef
So as you may or may not know, my 91 si had a swap to a d16y7. 2 weeks ago i had trouble starting it. I was told it was the fuel filter. So I put in a new one. Well a few days later I put my new header and cat back exhaust on but I didn't have my cat in the mail yet. So I started it with the open header to get a kick out of how loud it was. I went to start it again about an hour later so my friend could hear and it wouldnt start. He said maybe it was the electronic fuel pump. So I unhooked the batterie to restart the pump and voila, it started. I decided to let it sit for about 5 more days until i got the cat in from UPS. So monday morning the cat came in and I threw it on. To my surprise it wouldn't start; again. I decided to have it towed to my mechanic the same day. He wasn't able to look at it until tuesday morning. I get a call tuesday morning from my mechanic and he asked how long before the car dies, well I told him I couldnt get the ****er to start. He told me he didn't have any trouble getting it started. So he decided to let it set for a few hours. 4pm rolls around and he went to start it and it fired right up. He told me he couldn't find anything wrong, so I drove it home. Well today I go and get new tires and as I go to leave, it barely started then puttered off and died. For the next 30 minutes I couldn't get it started. Does anyone have any clue what it could be? I'm thinking distributor, fuel pump, and I was told maybe "slave cylinder"?
Old May 13, 2009 | 12:13 PM
zsatbecker's Avatar
try checking the fuel pump relay it could have got wet or something and corroded
Old May 13, 2009 | 01:07 PM
Is the CEL ON?
When you turn the key to ON(II), do you hear the fuel pump prime.
Do you have spark at the plugs? Click the Spark link in my signature.
Old May 14, 2009 | 06:51 AM
jrobs_ef's Avatar
Where is the fuel pump relay located? I turn the key but I hear nothing but beeps. It's weird, my car will start now just fine. It only happens on occasion
Old May 14, 2009 | 06:54 AM
jrobs_ef's Avatar
So yeserday I tried starting fluid in the intake and got it started. But, when we got it started it would just die. I would give it gas but it would just putter off. Seems like it was fighting for gas.
Old May 14, 2009 | 07:00 AM
Old May 14, 2009 | 06:30 PM
jrobs_ef's Avatar
So how can I tell if the relay fuse is good or not?
Old May 14, 2009 | 06:55 PM
The tests tell you whether the fuel pump and the wires in and out of the main relay are good. Do these tests first. If all is fine, I'll post tests for the main relay itself.
Old May 16, 2009 | 07:55 AM
jrobs_ef's Avatar
So is the main relay Mitsuba RC-2201??
Slammed98silvercoupe
14
Dec 19, 2010 05:16 PM
djt
Jun 21, 2008 07:48 AM
redlines4us
Aug 22, 2006 05:49 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
