Problems with 2001 honda civic lx
Old Jul 19, 2011 | 03:14 PM
lovemyhonda01civic's Avatar
Default Problems with 2001 honda civic lx
i have a 2001 honda civic lx & i was at a stop sign i pushed the gas to go & it suddenly died on me now when i try to start it it stays on for only a second then shuts off everyone my husband & i have come across says its the fuel pump but he checked it & he says it was fine now we are at a stand still as to what the problem could be so anyone with any suggestions will be helpful.
Old Jul 19, 2011 | 06:57 PM
Is the check engine light on? How did he check the fuel pump?
Old Jul 20, 2011 | 10:54 AM
droopy128's Avatar
Check the distributor (igniter and coil)...
Old Jul 20, 2011 | 07:14 PM
jcrag's Avatar
have someone stand back by the gas tank, turn the key until the auxillery comes on, you should be able to hear the fuel pump pressurize. If you cant hear that, its probably the pump. Otherwise, your not getting a spark if you can hear the starter turning over, check the ignition coil inside the distributor with a ohm tester, low side is like 12.5 high side is 19.0
Old Jul 26, 2011 | 03:36 PM
well i got impatient so i took my car in to be put up on the diagnostic machine & well it said that it was my crank shaft ignition sensor & that i needed a new timing belt & i needed a new waterpump. Soo i hella appreciate ur help & suggestions thank you everyone.
Old Jul 27, 2011 | 04:46 AM
jcrag's Avatar
yup, I talked to a Honda certified mechanic at the garage , he's been there 12 years and he told me in all his life he's never replaced a Honda fuel pump...
Scottydavi76
Apr 12, 2014 06:15 PM
hemplacrosse4
May 24, 2013 10:22 AM
Douglashdaniel
Feb 26, 2013 06:43 PM
escobedoca1025
Feb 19, 2009 04:46 PM
gunner671
Apr 26, 2007 12:18 AM
