Rear turn signal help
Old Sep 22, 2007 | 11:09 AM
Neon's Avatar
Default Rear turn signal help
So the other day my rear right turn signal quit working. I figured it was just the bulb so I switched the bulbs from the right and left turn signals, and it still wouldn't flash on the right side. So I switched the relay from the right side to the left side and the left turn signal quit working while the right turn signal worked fine. I'm assuming it's the relay.
The problem is that the guy who rebuilt the rear end of my car before I bought it put aftermarket tail lights on it, and I can't find any replacement relays for it. After unplugging it and replugging it in multiple times trying to find a replacement, it seems to be working fine for now.
I'm still worried it will quit working again so I was wondering if anyone knew where I could find a replacement relay, or maybe if there is anything I can do to my current relay if it goes out again, or maybe I'm just out of luck. I was also wondering if the connector that connects into the relay is the original that was on the car, that way if I wanted to get some SI tail lights whether or not I'd have to worry about the connector working with it.
This is on a 98 Civic EX coupe.
Here's the rear left turn signal.
http://img234.imageshack.us/img234/2...nsignaluh6.jpg
Is this connector stock?
http://img258.imageshack.us/img258/361/connectorcz8.jpg
The relay.
http://img255.imageshack.us/img255/6509/relayed9.jpg
The relay and bulb connectors.
http://img110.imageshack.us/img110/6...nectorsnf8.jpg
Thanks for your help.
Old Sep 23, 2007 | 07:08 AM
kinosh's Avatar
Default RE: Rear turn signal help
Can't you just take the relay to Honda and see if the connectors and amperage matches?
LucidSteel
Aug 1, 2010 10:26 AM
choestein
Jun 3, 2008 08:51 AM
Ty
Sep 11, 2007 06:31 PM
hondaowner
Jun 1, 2006 12:01 PM
rmvols31
Feb 13, 2006 10:00 PM
