rebuilding engine or fix
Old Apr 21, 2007 | 11:03 PM
dragonkx's Avatar
Default rebuilding engine or fix
Hi
I have a 2000 honda civic si. The pistons are bent or something the compression ratio dropped. So i was trying to decide to swap the internals to GSR (cams, pistons, etc.) It would still have the b16 block, or just install new stock or type r pistons plus type r cams. Any Ideas? If i decide to go with type r piston and cams will i need to get my ecu chipped? same goes for stock pistons and type r cams. Any Pros and cons about any of these?[/align]
Old Apr 22, 2007 | 06:57 AM
Street Sniper's Avatar
Default RE: rebuilding engine or fix
Bent pistons? Compression drop is probably the rings.
You obviously can't use ITR pistons in a B16, but the cams are good to go. A better choice would the be the CTR cams. They are the hottest OEM cam. Be sure to get at least the intake valve springs for the CTR too though if you do go that route.
As far as chipping the ecu- tuning is always a good idea- especially if you raise compression. With just the cams you might be ok without, but to get the most out of them some tuning should be considered.
Old Apr 22, 2007 | 04:53 PM
hondapwr's Avatar
it depends on what u want. new motor it will be on the road faster less trouble to. but if want boost rebuild for boost of fast n/a i would say up to u
Old Apr 22, 2007 | 04:59 PM
dragonkx's Avatar
well either way i have to open up the engine because of its problem, so i was told to upgrade and make it worth it. I got a bunch of spare parts, i got like all the gsr parts, from pistons, cams and everything internal. I was probably gonna swap the internals and make it a b16 gsr or something. But i also thought of just fixing the problems if its just the rods or rings, then maybe install some ctr cams. In your opinion which would make more power?
ghostbusters101
Dec 15, 2010 07:32 PM
deathlucky
Feb 26, 2007 11:28 AM
snosurfa7
Jan 8, 2007 09:52 PM
zerosystmusr
Sep 12, 2006 12:50 AM
fglaustin
Jun 8, 2006 03:47 PM
